Need help picking a universal remote for my JVC TV
I just picked up a used JVC TV that didn’t come with the original remote, and I’m struggling to find a universal remote that works with all the TV’s functions. Can anyone recommend a reliable universal remote model and share any setup tips or code lists that worked for your JVC TV?
Universal remote apps for JVC TVs on iPhone that did not waste my time
I went down this rabbit hole after my JVC remote died and the replacement remotes on Amazon looked sketchy or were priced like they were made of gold. I wanted to use my iPhone, no dongles, no IR blaster hacks, and no smart hub boxes.
Turns out, with JVC you have to pay attention to what kind of TV you have. Some are Roku TV, some Android TV, some older “smart-ish” stuff. A lot of remote apps say “works with everything” then quietly fail on half the models.
Out of a bunch that I tried, only two iPhone apps were worth keeping on my phone.
  1. TVRem Universal TV Remote app
    ‎TVRem Universal TV Remote App App - App Store
This one ended up as my daily remote for the JVC in the living room. The TV is on Wi-Fi, which matters here, because this app talks to the TV over your network. No extra hardware, no IR, nothing stuck to the phone.
What it does not try to do: pretend to be a fake “universal” that emulates every remote ever made. It sticks to the basics that you actually touch 20 times a night: arrows, OK, back, volume, source, home, and app launching. Less nonsense, fewer menus.
UI felt normal from the first minute. No flashing banners, no “watch an ad to use volume” nonsense, no 15-second delays. It loads fast, buttons respond without lag, and it did not crash on me once during a full weekend of use.
They also have a short demo video if you want a quick look before installing:
What worked well for me
  1. Free and no ads
    I kept waiting for the “watch this” screen. Nothing. I used it across multiple evenings, still no ad walls or popups.
  2. Wi-Fi control, no IR hacks
    It talks to the TV over your router, which is how most smart TVs expect to be controlled. If your JVC is online and your iPhone is on the same network, it should pop up in the app’s device list. No line-of-sight issues, works from the kitchen.
  3. Simple layout, no clutter
    The main screen looks like a remote, not a casino. Buttons are where you expect them. You do not scroll three pages down to find “Input”.
  4. Works with more than JVC
    I tested it on a neighbor’s LG and a random Samsung in a guest room. Same app, switched TVs in the interface, both worked. Nice if you tend to rotate TVs or you help relatives fix theirs.
  5. Feels like a long-term backup
    I unpaired it, re-paired it after a router reboot, and it reconnected without drama. I stopped thinking about it as a temporary fix. It is now pinned on my home screen beside the streaming apps.
What did not work
  1. No Apple TV, no Vizio
    It did not detect an old Vizio set or the Apple TV box. If those are your main screens, this would not replace their remotes. For JVC smart TVs though, it was fine.
  1. “TV Remote – Universal Remote”
This one is the typical “covers all TVs” app you see at the top of searches. It says it supports JVC over Wi-Fi, and on my older JVC in the bedroom it technically worked, but I had to wrestle with it.
On first launch it scanned the network, found the TV, then hung for a bit on “connecting”. Second try, it paired and I could control volume and power. So it was not fake, just rough.
The screen layout looks like someone tried to copy a real TV remote exactly, including buttons you probably never touched in your life. That adds clutter. It also leans hard on ads.
Where it did ok
  1. JVC over Wi-Fi
    Once it locked onto the TV, basic controls worked. Power, volume, channels, arrows, all responded. So as a backup it is not useless.
  2. Multiple brands in one app
    It offered profiles for lots of brands. If you bounce between different sets, it is one app to test across them.
  3. Backup if nothing else works
    I kept it on my phone for a bit as a fallback, in case the main app broke after a TV firmware update.
Where it annoyed me
  1. Ad-heavy interface
    Full-screen ads, banners, and delays. You tap something, and instead of volume you get a store ad. It breaks the feeling of “I am using a remote” and turns it into “I am using an ad-supported game”.
  2. Unreliable detection
    Some days it saw the JVC instantly. Other days I had to refresh the device list three times or restart the app. Same network, same TV, different mood.
  3. Sluggish and rough edges
    Response time felt slower than TVRem. Button presses sometimes lagged, especially right after the app opened from cold start.
  4. Update quality varies
    One update improved stability. Another update brought more aggressive ads. You feel like you have to re-evaluate it after each version.
Which one I ended up using
For daily use on a JVC smart TV connected to Wi-Fi, TVRem is the one I stuck with. Less noise, fewer problems, and it feels like something you can rely on when a show is starting and you need to unmute right now.
Apps like “TV Remote – Universal Remote” helped me test whether network control on the TV worked at all, but they felt temporary. Something you install in a hurry, use for a day, then forget once you find a cleaner option.
If your JVC is a smart model on Wi-Fi and you want a simple iPhone remote without extra hardware, this link is where I would start:
If you want a physical universal remote for a JVC, here is what has worked well for me and people I set TVs up for.
  1. Make sure what type of JVC you have
    Look on the back and in the menu. Check if it says:
  • JVC Roku TV
  • JVC Android TV / Fire TV
  • Plain HD/LED TV with HDMI but no real app store
This matters, because some remotes use specific device profiles.
  1. Simple, cheap option that tends to work
    One For All URC-3220 or URC-3680
  • Has JVC codes built in.
  • Handles power, volume, input, menu, arrows, OK.
  • Code 0478 or 0053 often works for JVC non-smart sets.
  • If one code misses a function like input or menu, try the next JVC code in the list.
  1. Better universal with more complete control
    Sofabaton U1
  • Works by IR for the TV.
  • You add JVC from their database with the phone app.
  • You can learn missing buttons from any cheap JVC replacement remote later, if needed.
  • Good if you also want to add a soundbar, Blu‑ray, etc.
  1. For JVC Roku TV
    Skip “universal” remotes that guess.
    Get an official Roku TV remote (voice or basic) that supports Roku TV brands.
  • It pairs as a Roku TV, not as JVC.
  • You get Home, OK, arrows, input, settings, app keys, everything the TV OS offers.
  1. For JVC Android TV
    Look for remotes labeled “Android TV remote with IR + Bluetooth”.
  • They work as standard Android TV remotes.
  • IR handles power and volume.
  • Bluetooth handles home, apps, Google Assistant, etc.
    Avoid super cheap ones with no reviews. Their Bluetooth pairing fails a lot.
  1. Where I disagree a bit with @mikeappsreviewer
    Phone apps are fine if your TV sits on Wi‑Fi all the time.
    For guests, kids, or a non‑techy person, a real remote tends to win.
    Phone app as backup, hardware remote as daily driver.
  2. How to test before you commit
    If you buy from Amazon or a big box store, test these functions right away:
  • Power on and off
  • Volume and mute
  • Input/source change
  • Menu, settings, and back
  • App or home button if it is smart
If any key misses, try another JVC code or profile before returning it.
If two profiles still miss important buttons, move to a Sofabaton‑type remote or a TV‑OS specific remote like Roku TV remote.
If you post your JVC model number and whether it is Roku, Android, or plain, people here can tell you exact codes or a specific part number that works.
If you specifically want a physical universal remote (not app‑based like what @mikeappsreviewer and @viajantedoceu focused on), here’s what’s actually worked for me with used JVC sets.
I’ll keep it to stuff that tends to give you all the core TV functions: power, volume, input, menu, picture settings, etc., not just “it turns on, yay.”
1. Easiest win for most plain JVC TVs
One For All URC 7960 / URC 3680 / URC 3220 family
I’ve had the best luck with the One For All remotes over the random $8 “For JVC TV” specials.
  • Built‑in JVC codes that usually cover menu, input, aspect, etc.
  • Code families to try: 0478, 0053, 0178
  • If one code is missing INPUT or MENU, try the next JVC code, don’t give up on the remote after the first attempt. That’s where a lot of folks think “this remote doesn’t work” when really it’s just the wrong device code.
These are boring looking but boring is good here. They’re less “universal circus” and more “everything works 95% out of the box.”
2. If you want to be sure you can get every weird button
Sofabaton U1 or X1
I slightly disagree with the notion that these are overkill for a basic TV. If your JVC has things like:
  • Separate AV / Component inputs
  • Picture mode / sound mode buttons
  • Sleep timer, subtitle, colored keys
then a learning remote is the safest bet.
Why:
  1. You pull JVC from their database first.
  2. If some function is missing, you grab a cheap JVC replacement remote later (even a sketchy $9 one) and learn the missing keys into Sofabaton.
  3. After that, you’re basically done forever unless you replace the TV.
Costs more, but if you also have a soundbar or set‑top box, it replaces multiple remotes and the pain goes down fast.
3. For JVC Roku TV models
No “universal IR” will ever fully beat a proper Roku TV remote.
  • Look for remotes labeled “for Roku TV” specifically, not just “for Roku players.”
  • They don’t care that it’s JVC; they talk to the Roku TV OS and give you:
    • Home, OK, arrows
    • Input, settings
    • Streaming app keys
    • Volume and power on the TV itself
You can sometimes get away with a One For All on JVC Roku models, but you usually lose some Roku specific shortcuts or have weird behavior in the Roku menus. For Roku TV I go native every time.
4. For JVC Android TV / Fire TV
You want an Android TV / Fire TV style remote with both IR and Bluetooth:
  • IR handles power and sometimes volume
  • Bluetooth handles Home, Back, Assistant/Mic, app navigation
A lot of no‑name remotes here are trash. Check for:
  • Actual reviews specifically mentioning Android TV or Fire TV
  • A dedicated Home button, Back button, and at least a D‑pad with OK
If your JVC is older “smart-ish” (pre‑Android, pre‑Roku), then treat it like a plain TV and stick with the One For All or Sofabaton route.
5. Stuff I’d personally avoid
  1. Ultra‑cheap “JVC‑only” remotes with 20 brand names in the title
    Half of them are clones that only cover basic power/volume and skip menu/input.
  2. Super fancy LCD touchscreen remotes
    Overpriced and often more annoying than helpful for one used JVC.
  3. Generic “supports 10,000 brands” IR blasters without a learning function
    If the built in JVC profile is incomplete, you are stuck.
6. How to sanity‑check the one you pick
When you get any universal remote, test these right away:
  1. Power on / off
  2. Volume and mute
  3. Input or Source
  4. Menu and Exit / Back
  5. Arrows and OK
  6. Picture or Settings, if the TV has them
If any of those are missing, try at least two other JVC codes / profiles on the same remote before returning it. Lots of people bail too early.
If you can post the exact JVC model number and whether it’s Roku / Android / plain LED, it gets a lot easier to recommend a specific remote and sometimes even an exact code to punch in.
