How do I properly stop screen recording on my Mac without issues?
I started a screen recording on my Mac using the built-in tools, but I’m not sure of the correct way to stop it without corrupting the file or losing what I’ve recorded. I’ve tried clicking around the menu bar and using keyboard shortcuts, but I’m worried I might be doing it wrong. Can someone explain the right steps to safely stop a screen recording on macOS and where to find the finished video afterward?
There are a few “correct” ways to stop screen recording on Mac without corrupting the file. Sounds like you started with either QuickTime or the Screenshot toolbar (Shift + Cmd + 5). Here is what usually works cleanly.
  1. From the menu bar icon
    • While recording, look at the top right of your screen.
    • You should see a solid stop icon inside a small square, or a circle with a square depending on macOS version.
    • Click that once.
    • Wait a few seconds. The file will process, then appear as a thumbnail at the bottom right, or it will go straight to your save location.
  2. With the Screenshot toolbar (Shift + Cmd + 5)
    • Press Shift + Command + 5 again while recording.
    • You will see the toolbar with “Stop Recording” on it.
    • Click “Stop Recording”.
    • Let macOS finish processing. Do not close your laptop or force reboot while it does that.
  3. With QuickTime Player
    • If you started the recording from QuickTime:
    • Go to the Dock, click the QuickTime icon.
    • At the top menu, click the little stop button in the menu bar.
      • QuickTime will then auto open the recording in a new window.
      • Use File → Save or File → Export and pick a location.
      • Wait for the progress bar to finish.
  4. Check where the recording goes
    Default locations:
    • Screenshot toolbar recordings, by default, save to Desktop or “Movies” or a custom folder if you changed options.
    • Click Shift + Cmd + 5, then “Options” to see and change the save location.
    • QuickTime saves wherever you choose when you hit Save.
  5. To avoid corruption or lost files
    • Do not force quit QuickTime while it is recording or finishing.
    • Avoid shutting down or closing the lid mid processing, especially on older Macs.
    • Keep enough free disk space. If your disk is almost full, recordings fail or corrupt more often.
    • Rule of thumb, leave at least 5 to 10 GB free for long recordings.
      • Wait a bit if you recorded something long. A 1 hour 1080p screen recording can be 3 to 5 GB or more, so processing takes some time.
  6. If the file seems missing
    • Use Spotlight: press Cmd + Space, type “Screen Recording” or today’s date.
    • Check Desktop and Movies folders.
    • For QuickTime, reopen QuickTime and check Recent Files from the File menu.
    • If macOS crashed, look in /private/var/tmp or /private/var/folders but that is more advanced and success is rare.
  7. Keyboard method (menu bar access)
    There is no default global “stop screen recording” keybind from Apple except through the Screenshot toolbar. The safest way is:
    • Shift + Cmd + 5
    • Click Stop Recording.
    Third party apps like CleanShot or ScreenFlow add hotkeys, but those are separate tools.
If you often lose recordings, try this flow:
• Start with Shift + Cmd + 5, pick “Record Entire Screen” or “Record Selected Portion”.
• Check “Options” and confirm the save folder and mic settings.
• After recording, always click the stop icon in the menu bar, then wait to see the thumbnail or finished file before touching anything else.
That routine keeps recordings clean and avoids half written files almost every time.
The stuff @caminantenocturno wrote is solid, but there are a few extra things that matter if you specifically want to avoid corrupt or half‑saved recordings, especially on longer ones.
  1. Don’t stop during “system stress”
    If your Mac is already gasping for air (fans spinning, apps hanging, tons of browser tabs), that’s when stopping a long screen recording is most likely to glitch. Before you hit stop:
    • Close heavy apps you don’t need (Chrome tabs, games, big Figma files, etc.)
    • Wait a few seconds if you just did something intense (exporting a video, running a build, etc.)
      Recording is already using CPU and disk; stopping / finalizing needs another spike of both.
  2. Let the thumbnail finish
    When you stop a recording, macOS often shows that little thumbnail at the bottom-right. People click it, poke around, close it, then instantly move or unplug things. I’ve seen files corrupt when:
    • The external drive was unplugged right after stopping
    • The Mac was put to sleep or lid closed while the thumbnail was still “processing”
      Safer routine:
    • Stop the recording
    • Wait for the thumbnail to appear and then disappear on its own
    • Only then move the file, disconnect drives, or sleep/shut down
  3. Avoid external drives for live saving
    Slightly disagree with the implicit “any folder is fine” vibe. Technically yes, but practically:
    • Don’t set the save location (Shift + Cmd + 5 → Options) to an external USB drive, network volume, or cloud-synced folder for long recordings
    • Save to local SSD first (e.g. Desktop), then move to your external or cloud after it’s done
      Network drives and cloud sync folders can interrupt writes or lock files at the wrong moment.
  4. Watch your storage before you record
    People check space after a fail, which is too late. Before recording:
    • Click the Apple menu → About This Mac → Storage
    • Try to keep at least 10–20 GB free if you’re doing long 1080p or 4K captures
      If you stop a recording when the disk is nearly full, macOS sometimes can’t properly finalize the file, and you end up with an unplayable .mov.
  5. Don’t force QuickTime to quit, even if it looks frozen
    If you used QuickTime and it looks like it’s hanging after you hit stop:
    • Give it time, especially after a long session. It’s usually transcoding or finalizing.
    • Avoid Force Quit unless you’re okay with losing the entire recording.
      If the UI is “Not Responding” in Force Quit, it doesn’t automatically mean the file is dead. Let it grind for a while.
  6. Use Activity Monitor as a sanity check
    For very long recordings:
    • Open Activity Monitor → search for “QuickTime Player” or “screencapture”
    • After you hit stop, check that CPU usage starts high then drops down eventually
      That drop means it finished processing. If CPU is still pegged, it’s still working on your file even if the window looks idle.
  7. Avoid stopping right after starting
    There’s a weird edge case on some systems where starting and stopping within a second or two can create a zero‑byte or tiny file. If you just mis‑clicked:
    • Wait a couple seconds before stopping
    • Or discard that one and test again with a short 5–10 second recording
  8. Do a “test stop” when it really matters
    If this is a once‑in‑a‑lifetime recording (presentation, client walkthrough, exam platform, etc.):
    • Record a 10–15 second test clip first
    • Stop it the way you plan to stop the real one
    • Confirm the file plays, has audio, is where you expect it
      Then start your real session with the exact same steps. Boring but saves a ton of rage later.
  9. If something looks lost, don’t restart immediately
    If the recording doesn’t show up:
    • Don’t instantly reboot; sometimes Spotlight or Finder is lagging
    • Wait 30–60 seconds and search by today’s date or “Screen Recording”
      Reboots can wipe temp files that might still be recoverable.
So, tl;dr for a “safe stop” routine that avoids most problems:
  1. Make sure you’ve got free space and your Mac isn’t at death’s door.
  2. Stop using the official stop button (menu bar or Shift + Cmd + 5, like @caminantenocturno explained).
  3. Wait for the thumbnail to appear and vanish, or for QuickTime to finish opening the file.
  4. Don’t close the lid, shut down, or yank external drives until all of that is done.
  5. Then move or edit the file.
If you follow that flow, it’s actually pretty hard to corrupt the recording unless macOS itself crashes.
Two things that neither @kakeru nor @caminantenocturno really leaned on: pre‑stop checks and post‑stop sanity checks. Both matter more than the exact button you click.
1. Before you ever hit Stop
  • Kill anything that might pop up a dialog at the end: Time Machine manual backups, disk cleanup tools, aggressive antivirus. If one of those kicks in right as macOS is finalizing the .mov, you get the classic “file exists but won’t play” problem.
  • Temporarily turn off automatic sleep:
    System Settings → Displays → Advanced → uncheck “Prevent automatic sleeping…” and in Lock Screen set “Turn display off” to “Never” for power adapter. Turn it back on after you’re done. Sleep during finalization is riskier than people think.
2. How you stop (without repeating their steps)
They already covered menu bar and Shift + Cmd + 5 / QuickTime buttons, so I will just add a nuance:
  • Use one stop path per habit. Constantly mixing “sometimes I click the icon, sometimes I bring up the toolbar” is how you forget what you did and think the Mac ate the file. Pick one method, stick to it, then you always know where the recording should land and what it will look like when stopping.
I mildly disagree with the idea that “there’s no global stop hotkey you can rely on.” There is not a dedicated one, but building the “Shift + Cmd + 5 then click Stop” reflex effectively becomes your hotkey. Practice that until it is muscle memory. It is faster in real life than hunting the tiny menu icon every time, especially on a multi‑monitor setup.
3. Right after you stop
This is where people actually lose stuff:
  • When the thumbnail appears, do not drag it somewhere else while it is still animating. Let it chill for a couple of seconds, then move or rename from Finder instead of from the thumbnail preview window. Directly renaming or trimming from that little preview has glitched on some macOS versions.
  • Confirm file integrity immediately:
    • Open it in QuickTime.
    • Scrub to the last few seconds to be sure it finalized.
    • If you are on a deadline, duplicate it (Cmd + D in Finder) before editing, so if your editor crashes, your original stays intact.
4. If the recording looks broken
Instead of rebooting or raging:
  • Check file size in Finder.
    • If it is 0 bytes or a tiny few KB, it never finalized. Nothing to do.
    • If it is large (GBs) but will not open, try QuickTime’s “File → Open” first, then VLC as a second opinion.
  • If apps refuse to open it but the size looks right, try copying it to another volume (like an external SSD) and opening it there. Sometimes local filesystem or permission weirdness is the culprit, not the video data.
5. Long recordings: reduce the risk up front
A couple of practical tweaks:
  • Lower the display resolution temporarily before recording. Capturing 1440p or 4K for hours is a lot harder on the system than 1080p, and that finalization step is what you actually care about.
  • If audio is critical, use a separate audio recorder app or device in parallel. That way, even if the video dies, you still have the audio track you can sync to a shorter “backup” screen capture later.
6. Very slight reality check on corruption
Most “corrupt” files from normal stops are really:
  • Saved to a location you forgot (Shift + Cmd + 5 → Options changed months ago).
  • Still being indexed by Spotlight or synced by cloud storage, so they lag in search or look locked. Wait a minute and try again before assuming it is toast.
Pros & cons of relying on the built‑in Mac screen recording tools
Pros
  • Integrated with macOS, so no weird drivers or background daemons.
  • Simple shortcut (Shift + Cmd + 5) and obvious stop behavior once you build the habit.
  • Output is a standard .mov that most editors like.
  • Zero cost and no watermark.
Cons
  • No global single‑key stop, you must use the toolbar or menu icon.
  • Finalization can silently fail if the disk is full or the Mac sleeps.
  • Limited controls for codec/bitrate, which matters on very long captures.
  • No automatic recovery if macOS crashes during recording.
Between what @kakeru laid out (all the “official” stop methods) and @caminantenocturno’s extra safety tips, you are basically covered on how to stop. The reliable routine on top of their advice is:
  1. Check free space and disable auto sleep for this session.
  2. Start recording, do your thing.
  3. Stop using your one chosen method.
  4. Wait, watch the thumbnail appear and vanish, then open the file and scrub the end.
  5. Only then move, rename, edit or shut down.
Follow that, and corrupt or missing recordings should become extremely rare.
