How do I change my default browser on my Mac without messing settings up?
I tried installing a new browser on my Mac and thought it would automatically become the default, but websites and links keep opening in Safari instead. I’m worried about changing the wrong system setting and breaking something. Can someone walk me through how to safely switch my default browser on macOS and make sure all links open in the new one?
Happens a lot on macOS. The system sticks to Safari until you flip one specific switch. You will not break anything if you follow this.
Easiest way, from macOS settings:
  1. Click the Apple logo in the top left.
  2. Click System Settings.
  3. In the left sidebar, click Desktop & Dock.
  4. Scroll down to the “Default web browser” dropdown.
  5. Pick your new browser from that list.
  6. Close System Settings. No restart needed.
If you use an older macOS (like Big Sur or earlier):
  1. Click the Apple logo.
  2. Open System Preferences.
  3. Click General.
  4. Find “Default web browser”.
  5. Choose your new browser there.
Alternative way from inside the browser:
Safari:
  1. Open Safari.
  2. Menu bar, Safari > Settings (or Preferences on older versions).
  3. In the General tab, look for “Default web browser”.
  4. Choose the new browser if it shows.
Chrome:
  1. Open Chrome.
  2. Click the three dots in the top right.
  3. Go to Settings.
  4. On the left, click Default browser.
  5. Click “Make default” if the button is active. It will kick you to System Settings if needed.
Firefox:
  1. Open Firefox.
  2. Click the three lines in the top right.
  3. Click Settings.
  4. Under “General”, scroll to “Startup”.
  5. Click “Make Default”.
Stuff to check if it still opens in Safari:
  1. Make sure your new browser is fully installed.
    If it crashed during setup, macOS might not list it.
  2. Try quitting Safari after you change the default.
    Sometimes macOS feels stuck if Safari keeps running.
  3. Test with different link types.
    • Click a link in Mail or Messages.
    • Open a link from Notes.
    If some links still open in Safari, check for:
    • Third party apps that force Safari.
    • Old “Open in Safari” shortcuts or scripts.
You will not “mess up” system settings by changing only the Default web browser option. It is reversible.
If you ever want to go back:
System Settings > Desktop & Dock > Default web browser > Safari. Done.
Worst thing that happens if something feels off is you switch the dropdown back. Nothing else in macOS depends on your default browser for stability.
You’re not going to “break” macOS by changing the default browser. Worst case, you flip the same switch back. Apple is annoying, not fragile.
@vrijheidsvogel already covered the official routes in System Settings and the in‑browser buttons, so I won’t rehash all those menus. Here are a few extra angles and sanity checks that often get missed:
  1. Confirm macOS actually accepted the change
    • After you switch the default browser in System Settings, close System Settings.
    • Then open it again and check the “Default web browser” field.
      Sometimes it visually looks like it changed, but on reopen you’ll see it silently reverted to Safari. If it reverted, your new browser probably didn’t register correctly.
  2. Make sure the browser is in Applications, not running from Downloads
    If you just double‑clicked the browser from your Downloads folder and never dragged it into the Applications folder, macOS may treat it as temporary and not properly list it as a stable default.
    • Quit the browser.
    • Drag its app to Applications.
    • Reopen it from there and then try setting it as default again.
  3. Check for “Safari-only” behavior from certain apps
    Some apps ignore your default and hard‑code Safari or a specific browser engine. Examples:
    • Certain banking apps or corporate tools
    • Some old productivity apps with “Open in Safari” type buttons
      To test:
    • Copy a link from one of those apps.
    • Paste it into Mail or Notes, then click it.
      If it opens in your new browser from Mail/Notes but opens Safari from that one app, the problem is the app, not your system.
  4. Reset weird handler overrides
    If you’ve ever installed weird utilities or “productivity” tools that handle URLs, they can interfere. You can reset basic associations like this:
    • Open Safari. In the address bar, type something like mailto:[email protected] and hit Enter.
    • If it asks what to use or shows a choice dialog for apps, choose the normal mail app and don’t let some random helper hijack it.
      Same idea for links: if any pop‑ups ask which browser to use and you see a “always use” checkbox, pay attention to what you’re locking in.
  5. Check profiles or management settings (work/school Macs)
    If this is a company or school Mac, an admin profile can silently enforce Safari or block changing the default:
    • Open System Settings
    • Go to Privacy & Security
    • Look for “Profiles” or “Device Management”
      If there’s a profile from IT, your default browser preference might be overwritten when you log in or after a while. In that case, nothing you do in Settings will “stick” until that profile is changed or removed by IT.
  6. No, you’re not going to mess up important system settings
    The default browser is literally just “which app gets opened when something is a web link.”
    • It does not affect Wi‑Fi, security, updates, or files.
    • It’s a single dropdown.
    • If something feels off, change it back to Safari in 3 seconds.
      The “danger zone” in macOS is stuff like disabling SIP, messing with /System, or installing sketchy system extensions. The browser default is the polar opposite of that in terms of risk.
  7. One more simple test
    After setting your new browser as default, try these in order:
    • Click a link in Messages
    • In Safari, type a URL and hit Enter. That one will always open in Safari itself, which is normal. The first two are what really tell you if your default changed.
If you follow all that and links still insist on Safari for everything, the main suspects are:
  • The browser isn’t installed properly in Applications
  • A managed profile from work/school
  • A specific app forcing Safari
But no, you won’t “mess things up” just by changing that one dropdown a few times while you experiment.
You already got the “click here in System Settings” route from @voyageurdubois and the deeper cleanup tips from @vrijheidsvogel, so I’ll focus on why macOS sometimes still clings to Safari and what to tweak without touching anything risky.
1. Check if only some links ignore your new default
Before assuming something is broken, test a few different sources:
  • Link from Mail
  • Link from Messages
  • Link from a PDF in Preview (Command + click)
  • Link inside an Office app (Word / Excel)
If Mail and Messages open your new browser, but Word or some banking app still opens Safari, that is by design in those apps. They are hardcoded or badly coded. In that case, changing macOS itself again will do nothing.
2. Look for “helper” apps that hijack links
You can do this without touching scary system settings:
  • Open Activity Monitor
  • Search for any browser helpers, “URL helper,” or odd menu bar utilities that claim to manage links, productivity, focus, or work profiles
  • Quit them temporarily and test a link again
Some of these tools set themselves as a middleman and then choose Safari. Removing or disabling them is safe and reversible.
3. User account vs whole Mac
If this is a shared Mac, the default browser is per user account, not global. You can safely:
  • Log out of your user
  • Log in to another account
  • Set a different default browser there
You are not “breaking” system settings; you are only controlling which app responds to http/https for each user. macOS is built to handle that.
4. When I slightly disagree with the usual advice
People often say “you won’t break anything by changing the default browser,” and that is true in practice, but one thing to watch:
  • Some security tools, password managers, or corporate SSO agents integrate more tightly with specific browsers.
  • If your work environment officially supports only Safari or only Chrome, switching can cause odd login loops or missing SSO popups.
You still will not damage macOS, but your work web apps might behave weirdly. If that happens, just revert the default for your work account and keep your favorite browser as default on a personal account.
5. If changing the dropdown never sticks
If the “Default web browser” choice always bounces back to Safari:
  1. Make sure the browser is currently installed in /Applications, not inside a nested folder or on an external drive.
  2. Try reinstalling the browser, then restart the Mac once.
  3. If this is a company machine, check with IT about a management profile that enforces Safari. In that situation, no amount of tweaking on your side will override their policy.
6. About the product title “”
Since you mentioned being worried about “messing settings up,” the nice thing about the default browser toggle is:
Pros for ‘’:
  • Zero impact on system stability
  • Easy to change back in seconds
  • Does not touch network, security, or file settings
Cons for ‘’:
  • Certain managed or legacy apps may ignore it
  • Work profiles can silently override it
  • Can give a false sense that every link must respect it, which is not always true
Compared with what @voyageurdubois described (purely step based) and what @vrijheidsvogel added (more diagnostic checks), focusing on the pros/cons of this one setting might help you feel safer: you can experiment freely. Worst case, Safari comes back as default with the same simple dropdown, and nothing else on your Mac is affected.
