I’m trying to clean up my Amazon order history by hiding a few past purchases, but I can’t figure out how to properly archive an order in the current interface. The menus and buttons look different from older guides I’ve found online. Can someone explain, step by step, how to archive an Amazon order and where to find that option now?
Yeah, Amazon moved stuff around a bit, so a lot of old guides look wrong now. Here is how to archive in the current layout on desktop. You cannot do this in the mobile app.
Go to Amazon in a browser
Make sure you are logged in
Hover over “Accounts & Lists” at the top right
Click “Your Orders”
Find the order you want to hide
- Use the search bar on the Orders page if you have a lot
- You can filter by year from the dropdown near the top
On that order, look for a small link or button that says “Archive order”
- On some layouts it is in the bottom left under the items
- On others it is in a three dot “…” menu on the right side of the order block
- If you see “Order details” and “Invoice” links, the Archive link is usually near those
Click “Archive order”
A popup will show asking you to confirm
Click the confirm button
After that, the order disappears from your main order history list.
To view archived orders later:
- On the same “Your Orders” page, look near the top filters
- Click the dropdown that says something like “18 orders placed in 2024”
- At the bottom of that dropdown, pick “Archived orders”
- You see all archived ones there, with an option to “Unarchive order”
Some limits and gotchas:
- Amazon caps archived orders at 500 per account
- Archiving does not delete the order, it only moves it out of the default view
- Anyone with access to your account can still see archived orders if they know where to look
- The mobile app often hides the Archive option entirely, so use desktop or mobile browser in desktop mode
If you do not see “Archive order” anywhere:
- Switch to a different browser or turn off ad blockers and extensions
- Try the desktop site from a phone browser, tap the browser menu and request “Desktop site”, then repeat the steps
- Check if you are on a country specific site, some regional sites have a slightly different layout, but the link is still in “Your Orders”
That is about all Amazon gives you for “hiding” stuff. There is no full privacy mode for orders, archiving is the closest thing.
Couple extra notes to add on top of what @yozora said, since Amazon’s UI likes to play hide‑and‑seek:
You still can’t fully “hide” an order
Archiving just moves it out of the default “Your Orders” view. It’s more like shoving it in a drawer than deleting it. It will:- Still show in your account if someone knows to look at Archived orders
- Still be used for “Buy it again” or recommendations sometimes
- Still show up on things like tax / invoice history
So if your goal is “nobody who ever touches my account will see this,” archiving is not enough. The only real protection is not sharing the account or using separate profiles/accounts.
Family / household sharing catches people out
If you’re in an Amazon Household or sharing Prime, other adults on the account may still be able to see archived orders if they go to the Archived section. Archiving is cosmetic, not a privacy feature. -
You can’t archive from:
- The mobile app (totally agree with @yozora here)
- The “Digital Orders” or “Kindle Content” pages in many regions
For some ebooks and digital stuff, there is literally no archive button at all. That’s not you missing it, Amazon just doesn’t give it.
Regional sites are inconsistent
I’ve seen:- .com having “Archive order” in the 3‑dot menu
- Some EU sites hiding it behind “Order details” first, then the archive link appears on that secondary page
So if you click into “Order details” and still do not see it, that specific order type might not be archivable.
Not everything is archivable
This is the annoying one. Certain orders simply do not show the archive option:- Some grocery / Fresh orders
- Some digital subs
- Certain third‑party services
In those cases, you’re stuck. There is no workaround besides using filters (year, type) to reduce how often you see them.
If your archive is “full”
Amazon caps it at 500 archived orders. If you hit that, you’ll need to:- Go to Archived Orders
- Unarchive some old stuff you no longer care about hiding
Then you can archive newer ones again. It’s a stupid limit, but it exists.
Tiny visual hint:
On desktop, if you hover over the order block and absolutely nothing clickable appears except “Order details” and “Invoice,” try:- Zooming out the page (Ctrl + minus on PC, Cmd + minus on Mac)
Sometimes the 3‑dot menu or archive link is just pushed off to the right and your layout hides it. Amazon’s CSS isn’t exactly elegant.
So yeah, you’re not going crazy, the interface really has changed and some orders genuinely just cannot be archived. Archiving is more of a “clean up the main list a bit” tool than a true hiding feature, despite how they kinda imply otherwise.
Couple of extra angles that might help, building on what @yozora and @suenodelbosque already covered:
1. Quick sanity check: are you actually on the “Orders” view you think you are?
Amazon has quietly split things into multiple “orders” areas that look very similar:
- “Orders” (physical stuff & most normal purchases)
- “Digital orders” (ebooks, apps, some subs)
- “Prime Video purchases & rentals”
- “Content & Devices” for Kindle etc.
The Archive option only shows on certain physical-type orders. If you’re in “Digital Orders” and you’re hunting for Archive, you can scroll all day and never see it. Easiest way to confirm: check the heading right above the list. If it says anything like “Digital Orders” or “Prime Video,” you are in the wrong place for archiving.
2. Specific order types that will confuse you
Even if you’re in the normal Orders page, some categories basically refuse to play ball:
- Groceries / Amazon Fresh / Whole Foods delivery
- Some subscriptions (Audible, channels, some Prime-related charges)
- Gift card reloads and balance transfers
- Certain third‑party services (e.g., install services)
If the order has no “Archive order” even after opening “Order details,” it’s likely one of these. That is not you missing a hidden button. Amazon simply does not expose archiving for that type.
3. Keyboard-only way to check for the hidden link
If you suspect your layout is cutting off the 3-dot menu or the Archive link:
- Open the Orders page.
- Click somewhere in the first order block.
- Press the
Tabkey repeatedly and watch for a faint focus outline moving across small buttons. - If you eventually see focus land on something that reads “Archive order” when you press
Enter, you found it even if it was partly off-screen.
This is occasionally more reliable than hunting visually on cramped laptop screens.
4. If you use multiple country sites
@yozora and @suenodelbosque are right that layouts vary by region, but one extra annoyance: orders are completely siloed by domain. If you buy on amazon.de and try to find those orders on amazon.com, they just will not be there to archive at all. Make sure you archive from the exact country site where you placed the order.
5. When archiving is not enough for privacy
Archiving is cosmetic. If your goal is to keep certain purchases out of sight from:
- Family using the same login
- A shared household computer where others might poke around “just to check tracking”
then all archiving does is reduce casual “scroll and see everything” exposure.
Better tactics:
- Use a separate Amazon account for sensitive stuff.
- Or at least log out after ordering and keep your browser from auto‑signing back in.
- Use different payment methods per account so your statements are not one big combined mess.
I slightly disagree with the unspoken assumption that archiving is a “privacy feature” at all. It behaves more like a cosmetic filter, closer to hiding completed tasks in a task manager than to any real concealment.
6. If your archive is turning into a dumping ground
You can only have 500 archived orders. If you are using archiving aggressively to tidy up:
- Reserve archiving for things you genuinely do not want to see in the main flow, not every single old order.
- Use year filters to tame the list instead of archiving large blocks of history.
- Periodically go into Archived orders and unarchive very old, low‑sensitivity items to free space.
Think of it like a “favorites” and “do not surface” system instead of trying to use it as a trash bin.
7. Troubleshooting when the UI just looks “wrong”
If everything described by others does not match your screen at all, try this in order:
- Use an incognito / private window with no extensions.
- Set your browser zoom to 90 or 80 percent so the full order block fits horizontally.
- Switch to a desktop browser on a laptop/PC if you were on a tablet; some tablet views are awkward hybrids.
- If you are on a work machine, check if any script-blocking policy is stripping out UI elements.
You should at least see a 3-dot menu or some compact menu icon on each order block. If that is missing across all orders, something is off with how the page is loading.
8. About that “product title” you mentioned
When you eventually find the archive option and start cleaning up, it can help to mentally treat archived orders as a kind of “reference-only” bucket in your account, similar to how you might keep a product like ' in a wishlist purely for later comparison. The pros of handling orders this way:
- Keeps your main history lighter and focused on active / recent items
- Reduces visual noise without deleting records you might need later
- Lets you mentally separate “normal purchases” from “things I prefer not to scroll past”
- Archive is capped at 500 entries
- Still discoverable to anyone who knows where to look
- Not available on every order type
In short: use archiving to declutter and mildly obscure, but not as a security or secrecy feature. For that, a separate account is still the only dependable method.
